Flat spot and vibration at 2000 rpm.
Old 06-09-2019, 11:44 AM
mtbmikeb's Avatar
mtbmikeb
mtbmikeb is offline
2nd Gear
Default Flat spot and vibration at 2000 rpm.
I have a 2009 FDXFSE 110 screaming eagle. Used and to my knowledge stock except the addition of a fuel pak (came with short shots, switched to big radius 2 into one)
Yep 110's run lean and hot. 4 weeks now, on the phone with Vance and Hines formulating maps. Running strong except for a flat spot around 2000 rpm that causes vibration. Vibration and acceleration improve above 2200 ish, and smooth as silk at 2400 rpm. Problem seems to be mainly present when machine is hot (closed loop?), and barely exists in cold state (one loop?) Plug gap good, no intake leaks. Any thoughts?
Old 06-09-2019, 08:29 PM
Max Headflow's Avatar
Max Headflow
Max Headflow is offline
Received 5,218 Likes on 3,603 Posts
Yeah, dump the FP and go with a PV or TTS and get it tuned.
Old 06-11-2019, 02:44 PM
mtbmikeb's Avatar
mtbmikeb
mtbmikeb is offline
2nd Gear
Yeah.
Just ordered a PV from FuelBoss yesterday. Tired of chasing a ghost.
Old 06-13-2019, 08:33 PM
mtbmikeb's Avatar
mtbmikeb
mtbmikeb is offline
2nd Gear
Default Follow up...
Just installed my new PV from Fuel Moto. They effin' rock! Bike runs great! 110 pulls like freight train and runs way cooler on the map they developed. Forever done with futile attempts navigating through weak VH maps and the inadequate level of support they choose to provide. FM actually works for your business. That's the **** this country was founded on.
Max Headflow (06-13-2019)
Airborne39
06-23-2014 07:31 AM
Iowa cajun
08-06-2013 12:11 PM
Colonelkat
11-25-2012 12:58 PM
toolman44092
09-20-2012 03:12 PM
bob53
10-10-2006 01:14 PM
Quick Reply: Flat spot and vibration at 2000 rpm.
