Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
I have a 2002 dresser I got on it and it ran good for about 2 miles and the guages went crazy and it just quit fuel pump want come on and it want fire . I replaced the crank shaft sensor no luck ,replaced the fuel pump relay no luck , checked all the fuses they are all good , I can take the cover off the fuel pump relay and manually make the pump come on but still no spark . Any help would be greatly appreciated
Sounds like you had a power surge that took out the ECM.. Most likely cause is loose battery terminals. Does the check engine light come on for 4 seconds and go out?
I fried my ECM a couple of years ago, it was a dead short from the battery to the frame. If I remember correctly it's pin 4 on the ECM that provides the ground and when that's gone it gives the same symptoms you described. Good luck brother, it will be an expensive day out.
