Harley Davidson Forums
Harley Davidson Forums (https://www.hdforums.com/forum/)
-   Ignition/Tuner/ECM/Fuel Injection (https://www.hdforums.com/forum/ignition-tuner-ecm-fuel-injection-55/)
-   -   Wanted a 07 streetglide ecm package with keyfobs (https://www.hdforums.com/forum/ignition-tuner-ecm-fuel-injection/1288333-wanted-a-07-streetglide-ecm-package-with-keyfobs.html)
dirtracer27x 06-14-2019 07:51 PM
Ok so want to get rid of my thunder max but I need a oem ecm. Anyone know where I can find one. I here on eBay but can’t seem to find a package deal.
springers4ever 06-21-2019 09:59 PM
Check this out
try these guys ....used the contact link or call them direct ..
https://www.ebay.com/usr/pinwall_cyc...72.m2749.l2754
https://www.ebay.com/usr/fallencycle...72.m2749.l2754
good luck ...
dirtracer27x 06-21-2019 10:58 PM
Thanks man I’ll try them
Max Headflow 06-22-2019 09:36 PM
First off. Key fobs do not talk to the ECM. They talk to the TSSM. The only thing you will need to do is program the ECM with the frame number of the bike. ECM and TSSM compare SNs at start of day.. I'm not an expert here. One of the HD techs or even Steve Cole should be able to give to good info.
Not sure why you are going back to stock. Tmax works well with the build you have in the footer. You will get about 1-3 less MPG tho.
© 2024 MH Sub I, LLC dba Internet Brands
