Bank angle sensor code?
Old Jun 4, 2021 | 06:00 PM
stevec1966's Avatar
stevec1966
Default Bank angle sensor code?
12 fatboy 103, bike intermittently
12 103b, 110 ci, S&S 585, PCV, 32 tooth compensator eliminator sprocket, torque cones,fuel moto injectors, 10.7:1, runs very well until it shuts off.
shuts off, pull to side of road, turn ignition switch off and back on bike starts, runs ok. Ck codes B1151 bank angle sensor. Can not find external BAS was told it's integral in BCM. Is this true and how can I bypass this.
Old Jun 4, 2021 | 06:19 PM
Max Headflow's Avatar
Max Headflow
Probably not a whole lot you can do other than replacement of the BCM. Dealer might be able to turn it off with a diagnostic tool but probably won't. On thing that I'd make sure is that the BCM is well mounted and at the correct position.
Shakee
Apr 22, 2020 10:50 PM
Saintsofmayhemvp
General Topics/Tech Tips
Aug 7, 2019 04:02 AM
Casting Crowns
Feb 27, 2013 08:36 PM
jeffwest5599
Screamin Eagle CVO Models
Jul 22, 2011 08:20 PM
shoveltrev
Exhaust System Topics
May 27, 2008 09:34 PM
