Screamin' Eagle Pro EFI Super Tuner
Old 01-25-2008, 12:06 PM
TickTock's Avatar
TickTock
TickTock is offline
Default RE: Screamin' Eagle Pro EFI Super Tuner
Will the software be available for download or will it need to be purchased?
Old 01-25-2008, 12:43 PM
deadwood1783's Avatar
deadwood1783
deadwood1783 is offline
The new software will be available on CD and will be updateable via internet. You will have to have the new software to use a SuperTuner dongle. As far as com one will not com with the other. You will be able to copy and paste tables etc. from an earlier version into the tables of the later version.
Old 01-25-2008, 01:52 PM
TickTock's Avatar
TickTock
TickTock is offline
I was just wondering if you could just load up the software without the dongle and test ride it around... For instance I can go to zippers website and download the tmax software and run it even though I don't have a tmax.
Old 01-25-2008, 02:28 PM
fxrp's Avatar
fxrp
fxrp is offline
ORIGINAL: Shovelhead Bob
ORIGINAL: 2005UltraNC
3. Any plans for automatic tuning in this or future SERT versions? Unknown at this point
So it's still 1976 2-wire, unheated, narrow band O2 sensors.
A new interface. Oh Joy Oh Rapture!
And a few minutes of memory in the dongle. Gee think they could afford it?
A turd by any other name smells . . . ??????
Old 01-25-2008, 04:42 PM
TickTock's Avatar
TickTock
TickTock is offline
[sm=popcorn.gif]Here we go again... [sm=headbang.gif]
Old 01-25-2008, 05:47 PM
movenice's Avatar
movenice
movenice is offline
I'm liking this Pro thingamabob! I will more than likely go this direction adding a FatCat & Doherty PowerPACC to the mix. If a picture is worth a thousand words, here's a thousand...
[IMG]local://upfiles/43215/6D348F3491DC44D4A41569F5DC3D1C0D.jpg[/IMG]
Old 01-25-2008, 05:55 PM
Shovelhead Bob's Avatar
Shovelhead Bob
Shovelhead Bob is offline
iF YOU HAVE nothing constructive TO SPEAK ABOUT, THEN DON'T......
You constantly extoll the virtues of the T-Max, but I have already removed 2 and gone back to SERT tuned ECM's due to the fact that the bike would pass everything except a filling station....
One custome had his done at Zippers in Md., not a happy camper.....
I know how to tune, and I take great pride in it... after all, the end result is more word of mouth business and my name in lights..... The SERT is a VERY SIMPLE to use tool (In the proper hands)....
Please consider yourself uninvited from this particular topic, as I do not wish nor desire to endure a long winded tirade from you on how the T-Max is so superior....
The end result is plain and simple....
THE TUNING DEVICE IS ONLY AS GOOD AS THE TECHNICIAN WHO IS MANIPULATING THE DATA....
Old 01-25-2008, 06:25 PM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
Big Kahuna HDF Member
So true. The real issue with the SERT is the HD dealer network doesn't have enough "real" tuners out there. I have spent several hundred bucks on a tune at a dealer where they wouldn't give me a copy of the map they loaded. They told me they had no "capability" to make a copy. ( hard to believe since my 9 year old daughter knows how to burn a file onto a jump drive) I have purchased 2 new motorcycles from them and will never set foot in one of their stores again. The "dyno" tune had to be re-done and the re-do was worse. So my gripe with a new tuner system which is really based on the old system is that they should train their dealer network before they release a new product.
Old 01-25-2008, 10:56 PM
Doc 1's Avatar
Doc 1
Doc 1 is offline
Train their techs before the product comes out.......Harley........never....lol
Old 01-26-2008, 01:13 AM
vettedog72's Avatar
vettedog72
vettedog72 is offline
Sounds like the newsystem will be easer to install/tune than the SERT. From the discussion above, I don't seea performance advantage over the SERT which can optimally change the fuel ratio and spark timing for individual cylinders by small increments of RPM. Iguess the changes in atmosphere, humidity, temperature etc are real important for the ultimate fuel ratio andtiming of the ignition at track side; but for street use, I don't see an advantage. All of that said, if the new tuner is easer for the tech to use, the $100 upcharge should be well offset by reducing the dyno time.Other wise, you can just down load any canned map that is recommended with out considering the individual charateristics of each motor, intake and exhuast.
If I was buying one today, only the leatest would do for me.
One more "if": if some computer savy motor head could make an add on dooda that would make the EFIget down with the idle sounds of the carburated motor he could have something as good as dolby is for sounds.
Quick Reply: Screamin' Eagle Pro EFI Super Tuner
