Removed Speedo Bike Wont Start
Old 01-11-2019, 04:38 PM
marcodarq's Avatar
marcodarq
marcodarq is offline
ps just for the record i just went back and checked the 01 XL FSM and yes you can get speedo codes out of it, but not engine management info.
m
Old 01-12-2019, 08:57 AM
bustert's Avatar
bustert
bustert is online now
well, mr. mar, you'll have to eat your words.
what the h$$$ is an ign module??? it controls the engine. since when did engine management apply only to efi, you know, even a distributor is an engine management item.
go back and do more research, there are more than speedo codes. you made a blanket statement which is not true, yes, some sportsters do have more diagnostics than others.
what is the diff between ign on the efi models and mine??? nothing!!!! i control curves, offsets and if i want, based off map, i choose not to, i run rpm base timing.
Old 01-12-2019, 09:57 AM
marcodarq's Avatar
marcodarq
every time you post up here you prove to the world of readers here how little you actually know. must be hard to live your life.
m
Old 03-03-2023, 10:37 AM
Josharleyracer's Avatar
Josharleyracer
Josharleyracer is offline
Stage I
Default Which wires needed to be grounded ?
Originally Posted by usaf_tim
Ok I have fixed it. I had to trace back the ground wires. There is 2 that need to be grounded that run out of the connector. So I just put a nice little connector on it and grounded it to the frame. Looks good and runs like a champ! Thanks for the help and if anyone else is thinking about removing their headlight I can help ya out.
Which connector ? The instrument wiring harness or other connectors under tank ?? The wiring harness I need Harley doesn’t make anymore of course I can find connectors and make my own but really tired of broke things sooo plug and go is how I’m trying to do this lol
Old 03-03-2023, 01:53 PM
roussfam's Avatar
roussfam
roussfam is offline
Received 6,710 Likes on 3,490 Posts
Try a PM
q2418130103p
07-23-2021 07:31 PM
Harvey2013!
01-09-2014 01:37 AM
tujo33
EVO
06-28-2010 09:16 PM
Nonstop
06-28-2009 04:21 PM
dguse
02-01-2009 02:47 PM
Quick Reply: Removed Speedo Bike Wont Start
