Daytona Sensors Twin Scan II
My fuel injected 04 Ultra has had a problem for a couple of years I have yet to locate. I also had it to the local dealer, and they did not find the problem either. After running for awhile at cruising speed, when I stop the bike will idle down very low and probably die unless I baby the throttle and front brake at the same time. The bike is very intermittent in the slow idle. After it does it once, I may ride all day and it doesn't happen again that day, or it may happen again 5 minutes later. I bought the Daytona Sensors Twin Scan II engine monitoring sensor to try to isolate the problem. While connected, the bike stumbled only one time. Viewing the logged data, the rear fuel injector pulse width fell to near 0 at that point. The front injector did not, it had a peak and then leveled off. After I bumped the throttle, the rear injector leveled off too. Now my question, what is the Twin Scan II actually looking at to arrive at the Front and Rear Injector waveforms? Is the ECM, the injector, or some other sensor the top suspect? Any help will be appreciated.
04Ultra
04Ultra
