Running lights/trun signals
I just recently relocated my rear turn signals on my '05 883C. I used the light bar from a Softail Touring Model. Everything works fine and to me it looks great. This mod got me to looking into being able to convert the trun signals to running lights also. The Module that HD sells would allow me to make the Turn Signals, Brake lights also, but does not make them Running/Tail lights. Can anyone offer some help, or is this impossible due to wiring issues? I would like the lights to be Turn/Brake/Running lights. I have checked most of the post I can find about rear turn siganls.
Thanks. |
RE: Running lights/trun signals
I don't know about sportsters, but for softtails Kuryakyn makes a simple plug in module that does what you want without any changes to wireing. It is also a load equilizer if you want to go to LED bulbs. $70 to $75. on a soft tail it just plugs in under the seat. Kuryakyn also has a system called Panacea that usaes a LED tail light that does the same functions, but (if I read it right) lets you have red running and brake with amber turn signals. Again not sure about the Panacea functions or if available for sportster, not available for 2000 and 2001 softtail. Ernie-Seattle
Thanks Dude! Being as I used a Softail light bar it is probably good to go!
© 2024 MH Sub I, LLC dba Internet Brands
