TTS Mastertune Information
  #4361
Old 10-20-2013, 06:37 PM
hosh's Avatar
hosh
hosh is offline
By zeroing out the Adaptive knock retard Mr Wizard, do you mean setting all fields to zero?
Is this something new? I didn't read this in the VTune setup instructions.
Thanks
  #4362
Old 10-20-2013, 07:31 PM
Mr. Wizard's Avatar
Mr. Wizard
Mr. Wizard is offline
Administrator
Received 2,035 Likes on 1,103 Posts
Thanks
Yes, that is what I mean.
Some people will work with timing at the same time they work with VE. This is incorrect but learned spark events can obscure VE values so it is best to leave them set to zero. This will not turn off knock retard protection, it just doesn't remember where the knock retard events were.
Attached Thumbnails TTS Mastertune Information-knock-retard-table-to-zero-2.jpg
  #4363
Old 10-20-2013, 07:33 PM
BearShit's Avatar
BearShit
BearShit is offline
Originally Posted by Mr. Wizard
Those are extremely small files. 30,000 + is more like it.
I would definitely recheck to see if you have a VTune file in your bike. There will be no data in open loop.
OK proper file in Bike today...Noticed FR only likes around 750/760kb of data..bout 3/4 of an hour running steady..did 2 Runs 4 files each And no EGR analysis tells me needs TPS MAP n Engine RPM to plot graph, Playback in Datamaster2 has all that in the Vtune Runs though ?? Now it did want Datamaster when i upgraded with FR i use datamaster 2..open to suggestions if someone has time ..Nice to run without laptop battery worry thats for sure
  #4364
Old 10-20-2013, 07:49 PM
hosh's Avatar
hosh
hosh is offline
I see. I haven't strayed into any advanced settings as yet. I gather after I have completed a vtune run and generated a new tune I would reset Adaptive Knock Retard tables to Original on the new calibration?
Thanks
  #4365
Old 10-20-2013, 08:14 PM
Mr. Wizard's Avatar
Mr. Wizard
Administrator
Thanks
When you are done VTuning and are satisfied then reset all values you changed for the VTune calibration back to original.
AFR or Lambda
PE Mode
  #4366
Old 10-20-2013, 08:15 PM
bakes68's Avatar
bakes68
bakes68 is offline
5th Gear
Bearshit im having the same problem with egr analysis, tried on a older version of software and worked fine, may be in the upgraded software.
  #4367
Old 10-20-2013, 08:19 PM
Mr. Wizard's Avatar
Mr. Wizard
Administrator
Those files are too small, way too small. Something isn't right. I had J1850 data up in the 30,000 plus within the dongle. After importing the dongle files into the computer they were much, much smaller. So, are you talking about dongle files or imported data files?
I found the EGR error today and sent a note to TTS to review the software code settings. This has to be a software bug.
  #4368
Old 10-20-2013, 08:27 PM
bakes68's Avatar
bakes68
bakes68 is offline
5th Gear
Glad it wasn't just me
  #4369
Old 10-20-2013, 10:30 PM
hosh's Avatar
hosh
hosh is offline
AFR or Lambda
PE Mode
Too easy thanks Mr Wizard
  #4370
Old 10-21-2013, 07:43 AM
BearShit's Avatar
BearShit
BearShit is offline
Good to hear i aint alone, gotta love how Wiz gets right on that
Quick Reply: TTS Mastertune Information
