Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Is there a way to convert or read a map from the older Race Tuner to the newer SE Pro Super Tuner? I have a pretty good map in the older version that I want to use. My older SERT was damaged by a dealer and replaced with the newer one.
VE and timing tables can be cut/pasted, but the background info ( tables that aren't accessable) may be different. You'll have to have SEST open with an appropriate base map, and SERT open with your good map.
It "should" be fine
HTH
Robin
It "should" be fine
HTH
Robin
