Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
check engine light, hi idle speed and code P0505.
problem turned out to be one of the screws on the throttle body butterfly had come off and the butterfly would not close. Fortunately, the screw stayed in the air cleaner and did not go through the engine.
what about the injectors??? Did you also purchase the higher flowing injectors to be used in the 58mm tb.... They are not included in the kit... And if they are not installed, the tuning map is not correct, as the duty cycle for the injectors is not correct..
