Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
I am installing a stage 1 with PCIII usb. The bike's top speed is around 100mph and then the fuel cuts out to slow the bike. Will the PCIII remedy this or do I need a download from the dealer before or after the stage 1 upgrade?
Just so I get this straight. I install the exhaust and AC. should I get the download before adding the PCIII or after. I have read other threads and not sure if it matters but if it does I want to know. I have the items in my garage at home. Will be doing the installs when I get there in January so I am lining up my ducks now.
If its the pc3 usb it has a rev extend to 6200. Plug into your pc "bike runnig" or use the 9v adaptor, hit control/F to pull up that option check it off and send map to pc.
PCIII won't modify the rev limiter. You would have to have the Stage I download, or use the Harley tuner or the TTS tuner....
Originally Posted by qtrracer
Yes you will have to get the ECM reflashed by the dealer to up the rev limiter or buy the rev extend that dynojet sells.
This is incorrect. The PC III USB as well as the PC-V allow you to raise your stock rev limiter to 6200 RPM's which is about as high as you want to safely rev these motors. This is very simple to do. Open your PC III software and connect to the unit, either turn on the igntion switch or start the bike and hit the control & F keys which bring up a box and you will check 6200 RPM limit. With PC-V you connect to the software, go to configuration/RevXtend and check 6200 RPM limit.
Not for nothing but the Dynojet webpage is giving out the incorrect info then because I was on it just now and that is how Dyno jet is marketing the Rev Extend , "No longer will you have to take your bike to the dealer to have the ecm reflashed in order to have the higher rev limit your bike needs with modified cams heads etc." PC III USB Additional features for Harley Davidson. I'm sure your right so Dyno Jet is providing incorrect info so we will purchase Rev-xtend unnecessarily then? What am I missing?
I just got it thanks , rev extend is included with the PC III USB does not cost extra . I am a slow learner.
