Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
IS that code for throttle position? I recently replaced my grips and ever since the throttle cables are real loose under the throttle grip housing. Don't know how to fix that.
That could have something to do with it. Have you tried tightening up the cables as much as possible?
I think what I will do is reset the code, and see if it shows up again. If it does, then perhaps if someone can give me the part # I will replace the sensor. After that, I guess I have to think weather or not my PowerCommander is messing up or something. Any suggestions?
