Brake light stays on
Yep....the front brake switch is "held in" by a little ear on the lever. Sometimes, as they age this little ear will wear a bit and let the switch button release far enough to keep the light on. Even if things are all lined-up. When you ride behind one going down the road and his brake light is flickering....it's usually a worn lever. The HD folks like to just sell you another lever. All you have to do is put a screw in the little ear on the end of the lever and file it down until you get the light to operate properly. It use to be a real common problem in the mid-to-late 90's models. That little ear almost looks like a casting on the end of the lever they forgot to machine off, but it's there for a purpose.
Another case of a $20,000-plus bike with a designed component that looks like an accident. You can make sure which switch is causing the problem by just un-plugging one of the leads off your rear brake-light switch. That will kill the rear switch and cut your trouble shooting in half.
No brake lighta t all!!
I haver a 2009 Dyna Fat Bob that the brake light does not work at all. The running light works just fine, but no brake light. I have checked the bulb, and actually replaced it, but still no brake light. No light from the front lever, or the foot lever. Checked both switches, and nothing seems to be wrong. Checked fuses also. I put a test light on the mini harness to the bulb, and no signal is getting to it. Help please.
Thanks for the tip with the screw, sorted me out just nice.
