popping on throttle letoff
RE: popping on throttle letoff
The bike is new to me and the plugs where new when i changed them agin, although i just put the v plugs in it and it did help some and borrowed a buddys af tester and it was at 13.4, I think i need to check it riding throughout the rpm range now.
thanks, also i ordered a twin scan to check for codes. any advice is welcome.
thanks
thanks
I have an 03 EG with EFI and a Power Commander III. My experience has been that the popping is due to a lean condition on the zero degree throttle position. If you're running a PCIII, you could try increasing the values in the zero column in the lower RPMs say 5 increments and see if it helps the popping. If you're not running a PCIII and havew not made any exhaust or air intake changes, I'd vote for checking for an exhaust leak. Just my 2 cents worth....
Tommy-Law
09-04-2013 06:17 PM
carbureted, carburetor, davidson, exaust, exhaust, harley, leak, letoff, pop, popping, pops, samson, throttle, thunderheader
