Power Vision Information Thread
#8861
I bought my PV auto tune last year and ran the program that fuel moto loaded into it for me. During a couple rides last year my screen went very washed out and streaky but it returned to normal after restarting the bike. Yesterday was my first ride of the year and the screen will not display normally, it is like the contrast is very bright and has colored streaks running down the screen. I can not read the screen unless I tilt the unit away from me and try to read it from a bottom angle. Any one ever had this happen?
#8862
Been a while since I chatted up in here and have a quick question.....
When I first got my PV and TT... I ran a 1074x TH and now with D&D Boss Boarzilla and need to re-tune.
I was told to run a short 20-30 mile cruise and apply it... then change my Kpa setting... and run the rest....
What should my Kpa settings be to run AT once again? Is one setting better than the other?
Thanks....
Thanks....
#8863
#8864
there is a noticeable difference in performance. And yes. AY is easy... just need to know what kpa settings should be at as I can't remember
#8865
Making the 6 Pin Connector a 4 Pin
I also created a separate thread but thought some people may pay more attention to this sticky, and not the other threads.
Has anyone changed the 6 pin connector to a 4 pin? Have a pv-2 with the 6 pin cable. Need the 4 pin, making it a pv-1.
Someone with a PV-1 4 Pin cable could ohm out the four wire pins to the 8 wire connector.
Also, I found this pin out on another forum:
Top row from left to right:
12V +, CAN High, N/A, Ground
Bottom row from left to right:
J1850, CAN Low, N/A, N/A
For 4 pin aplications up to 2011 You need to connect:
12+ from PV to Grey wire on DLC socket
GND from PV to Black wire on DLC socket
J1850 from PV to Light/Green wire on DLC socket
And yes, I realize a 4 pin cable can be purchased.
#8866
Sert Help
Can someone point me in the right direction regarding tuning with SERT? Im new here and cant seem to figure out how to start a new thread. So, sorry about the jump.
Anyways, I'm trying to get rid of a little Rev Hang between shifts on my '04 FLSTCI. Stage 1, with V&H Pro Pipe. Is it a lean condition in the 0 column?
#8868
Question for the PV guru's here on the forum:
I have an '06 Ultra 88inch running SE stage 1 AC with K&N filter, B&E true duals with B&E Superflows and recently installed Andrews 21 cams. With the 2 different maps provided for the V&H fuelpak the bike is running rich at start up, runs ok but the mpg is 33 on average and per V&H that is normal, do not have any additional map/help because of the cams
So the question of the day, if I purchase a PV through FuelMoto, will I see any improvements (Is it worth the coin spent)? You all use them so you are the best sounding board and I am aware I will not be able to use the AT feature not having o2 sensors so will be depending initially on the map provided by FuelMoto. Thanks in advance for your reply!
#8869
#8870
