Power Vision Information Thread
#9071
The Auto Tune Guide from DynoJet -
http://www.powercommander.com/downloads/Support-Released/Manuals/PVAutoTune.02.pdf
DynoJet AutoTune Video-
https://youtu.be/y-x9NcQ5TWc
#9073
Yes it will tune your bike with cams. Just putting the cams in and running autotune won't work real well. What you will need is a starter map for the particular cam you chose. Fuelmoto web site has lots of information on this and cams to choose from with dyno sheets. They also have starter maps for the cams on their website. Don't worry about having to select the just right cam with all the magic in it. There is a dyno chart there that compares a lot of the popular cams. Not enough difference to make me pull my hair out trying to select one that is going to out perform everyone else.
ScoopsLR (06-21-2018)
#9074
Here's a question......just installed the canned tune provided by Fuel Moto with the new PV I just received. I advised FM that I have S&S Grand National slip ons without baffles and a current SEPST canned tune installed on a '18 FXFBS. The tune file was named "Stock Improved" from FM. I have not ridden the bike as of yet (tomorrow) but are these M8's tuned that well from the factory that just adding slip ons (cat in header on the FB) doesn't need that much tuning?
#9075
#9076
But you will see an improvement with an FM tune in there.
#9077
#9078
#9079
You will find being loud does NOT make horsepower. A properly tuned exhaust will make the best horsepower, low end and mid range torque, and millage. You will find tuning will go much better with the proper back pressure. It also helps take care of exhaust reversion at the valves.
What I meant by no baffles in the S&S slip ons is the optional dB killer inserts have been removed. The mufflers themselves have all the baffling in place as designed.
#9080
Today I ran the wire up the backbone to the bars and mounted the unit. I went to initiate Auto tune and it said I needed dealer info and it would not turn Auto tune on nor would the Quick Tune feature work. Same deal as Auto tune. What gives?? I paid for this unit and I can't even access all features? Is this something Fuel Moto was responsible for activating???
