proper air fuel mixture
hey everyone
i recemtly had cams put in my bike,
the guy that did the cams does not have a dyno so he downloaded a map on my power commander 3
the cams were making alot of noise, in hopes of helping the noise i went to harley and had them dyno the bike
it still has the noise and still runs good but doesnt seem to have the power it did when taking off and getting going, it also runs a little hotter
as best as i can tell from the dyno sheet the air fuel mixture is at 13 to 1 through all throttle positions,
is that the best mixture, should i richen it up a tad at idle and maybe 1/8 throttle position
if so i have the disc that came with the power commander, could you guys walk me through it
by the way ,once going it runs like a bat out of hell, just seems a little weak taking off , that is comparing it to the map that was loaded
thanks
sean
03 road king
stage 1 air cleaner
30002 crane cam
reinhart tru duals
power commander 3
thanks
sean
03 road king
stage 1 air cleaner
30002 crane cam
reinhart tru duals
power commander 3
