Please help me find a SERT map!!!
Ok guys, just took my bike apart and I cant believe the engine never blew up! It was running soooooo lean! It is an 06 softail and it has a thunderheader, SE air cleaner and a black SERT. I bought the bike like this and it seemed to run really nice. I took it apart to put some andrews 37 cams in. When I took the t header off I could not believe how hot the exhaust ports were! no trace of carbon on anything, plugs are white, even the valve stems are coated white. So i want to change the map before I even start it with the new cams. Can somebody help me out with a map that is close to my setup or suggest a "canned" sert map that will be closer. Thanks for the help!
joesbike85
03-29-2011 04:25 PM
arachman
07-15-2007 10:47 AM
