Bad starter clutch....?
The bike is a 2000 Fatboy. When hitting the starter switch the pinion gear engages the starter ring on the clutch hub and trys to spin the hub.
http://www.youtube.com/watch?v=C2oos...layer_embedded
When I let-off the starter switch, the pinion gear stays engage and I have to 'tap' it to return to the 'rest' position.
Could this be a starter clutch issue? Any help or direction is appreciated.
My starter clutch has just packed up. It just whirrs at high speed, making a pretty unpleasant noise, with no motion from the engine. I'm about to dive in there to see what to do about it!
