Run-brake-signal Controller
I heard HD makes the above controller to run the stock 1156 turn signals as run-brake-signal lights. Any comments re this add-on?
Thx! |
RE: Run-brake-signal Controller
It works pretty good.....
Simple plug and play..... Definitely more light on the azzend in the dreary eves of fall and winter..... |
I have the one that acts as brake & turn not running lights. Easy install, plug and play.
Lights up really nice. |
definitely a good addition
Kurykyn makes one also, it converts turn signals to running lights and brake lights(they still function as turn signals) but pulse three times before going solid red when you apply the brakes. You will need red turn signal lenses (they come with the HD kit. |
I installed the H-D R-T-B kit as soon as the dealer got one in (I didn't want the olderversion that did brakes only). Extremely easy installation, and it significantly increases your visibility to following traffic. I highly recommend it.
© 2024 MH Sub I, LLC dba Internet Brands
