Enough with this Kuryakyn Panacea controller...
OK so I have the Kuryakyn Panacea light. Fit and finish is nice, but the controller is annoying.
Firstly, it only has two modes: a) "DOT" mode which is brake on-off only b) "Panacea" mode which activated integrated flashers, and also flashes the brake light 6 times over 3 seconds when you press it Also, the load equalizer that it comes with can't handle much, they expressly state DO NOT run 4-way hazards . ever. haha Well, I want to liberate myself from these limitations. I specifically want just regular solid-on brake light but do want the integrated flashers. Also I want a legit load equalizer just incase I need to run those 4-way hazards. I have a few ideas, but what do you experts say? I'm not sure but it seems the controller intercepts the stock harness connector and outputs the same stock connector.. so I imagine maybe just get a different controller? |
© 2024 MH Sub I, LLC dba Internet Brands
