DTT ignition on carbed bike
i just replaced my se ignition module with a new dtt tc88 ignition, been reading on setup and settings, looks like there is alot of variance between setups. On the setup sheet it says with a stock, or mild engine build running premium gas, to start with settings at 5 and 7, but from searching, some guys are running 2 and 2, etc. My bike is a 95" @ 9:8 compression, 37 cams, pipe, etc, but i would guess its still considered a mild engine..anybody with similar engine specs running the dtt? Whats your settings? I havent bought the cables yet for a custom map..figured id try it out like it is first.
