Auxiliary brake light/turn signal conversion kit
I installed an auxiliary brake light/turn signal conversion kit (red lens) on my FLHTI 2004. They work just as they should: they braked and flashed whenever the command is given.
My question is how to have my rear brake/turn signal on all the time (parking light), i mean just like my front flasher are turned on when the ignition is on?
Do i need to change the socket for one similar to the front flasher and add a third wire from my brake light to each of my rear flasher?
Michel
Quebec,Canada
[IMG]local://upfiles/3739/05DAFCA1823A42D595B29F52F51E4A36.jpg[/IMG]
Michel
Quebec,Canada
