'69 xlch n/r project-clutch issue
liked the way it looked, hauled it home (kick & electric): i push the clutch basket on shaft and it rubs on kickstart nut (nut shows the same thing has occurred on past repair/rebuilds). basket seems to be in really good shape, not warped etc. Bearings (2) were replaced, no probs there. The starter ratchet gear spacer should make contact w/the basket bearings washer if i remember right but it doesn't. The start gear spacer for a '71 is longer, thought about trying that. Anybody ever run into a similar problem ?
thanks
starter not disassembled but kicks over, parts that can be seen in primary side look properly positioned and no play noticed. The only thing of interest is the nut which I ASSUME is the right one but in trying to remember from the past (worked for an H-D dealer for a couple of years in mid 70's), I don't remember the nut having a raised shoulder around the shaft bore. Waiting on a socket , I'm gonna take the nut off and check a little closer.
