Ironhead A place to talk about Ironheads.
sporty rear wheel
Old 09-08-2017, 11:09 AM
grinder678's Avatar
grinder678
grinder678 is offline
Stage I
Default sporty rear wheel
i,m looking for an 18" rear mag for a 1983 sporty factory mag wheel, not having much luck.
Old 09-08-2017, 12:57 PM
AJSHOVEL's Avatar
AJSHOVEL
AJSHOVEL is offline
Received 10,362 Likes on 4,111 Posts
I believe in '83 it should be a 16" from the factory.
Old 09-08-2017, 07:54 PM
IronMick's Avatar
IronMick
IronMick is offline
It is virtually impossible to find correct year IronHead parts if you do not have the Factory Parts Catalog in hand. The FPC that you need is 99451-85A.
On page 63 you can see that the correct part number for the wheel is either 41015-82A or 40983-83A, depending on the model you have [XLS. XLX, XL].
Now you can do proper Google, eBay, Internet etc searches.
Note also that getting wheels that fit is difficult to do. There are too many similar ones. Often you cannot tell until you have it in hand and are trying to fit it.
One source is sites like J&P Cycles. They often post year fitment ranges for the parts.
I bought a rear wheel for my 1980 IronHead some years ago. It was said to be a later 1980s wheel for some HD product. I had to do significant grinding on the brake rotor side to get it to fit. Then it worked perfectly.
Old 09-12-2017, 10:00 AM
83XLX's Avatar
83XLX
83XLX is offline
An 18" cast rear wheel from a '79 is about your only option.
71_FX_Superglide
Shovelhead
16
06-21-2016 04:28 AM
roundy
03-18-2013 10:48 AM
cowboy 51
EVO
15
02-18-2013 11:19 PM
bigbeats01
10-15-2012 07:36 PM
1200efi
Ironhead
11-28-2009 07:56 AM
Quick Reply: sporty rear wheel
