Ironhead A place to talk about Ironheads.
Points Screw
Old Apr 24, 2021 | 08:43 PM
lownslow's Avatar
lownslow
Default Points Screw
Hey lads,while installing new points I gave the breaker plate screw a little too much ooomph and it stripped out. Timer threads look fine, the screw is **** though. Tried all kinds of tap and die stuff but it think the threads in the timer plate are boogered up just enough to make things difficult. Does anyone happen to know what thread pattern that screw is? I could retap it to a slightly larger size but that may start to interfere with the breaker plate slightly. I've run in an 8/32 screw which feels good and tight for a couple turns but then stops. Thoughts?
Old Apr 24, 2021 | 09:04 PM
Joe12RK's Avatar
Joe12RK
helicoil
Old Apr 24, 2021 | 09:10 PM
lownslow's Avatar
lownslow
Joe, it's a pretty small hole for a helicoil.
Old Apr 24, 2021 | 09:21 PM
TexasScooterTrash's Avatar
TexasScooterTrash
So ya still got 1 machine screw ya can tighten. Try some Locktite Thread Maker.
Old Apr 24, 2021 | 09:31 PM
lownslow's Avatar
lownslow
Scooter, this is the screw for the breaker plate, only one, adjusts the point gap. Timer threads good, screw bad.....
Old Apr 25, 2021 | 05:42 PM
The Doctor71's Avatar
The Doctor71
I think you'll find that screw is #8-36 UNF..... but verify it before you go too far. On my '71 xlch, it's #8-36 but I don't know your ride.
Regardless, whatever you end up putting in there....... confirm you only have a few thou or two (0.001" - 0.002") sticking out the back side. Failure to catch this and the screw will hit the mechanical advance unit & chew your advance unit all to hell.
Old Apr 25, 2021 | 06:24 PM
lownslow's Avatar
lownslow
1970 XLH, sorry bout that. Put in a new screw and cut it just a hair longer. Running good, amazing what a fresh set of points will do.
SnoRider
Mar 20, 2016 07:01 AM
03snake
Jun 26, 2014 10:07 AM
toddlaroche
Jul 20, 2013 06:32 AM
thelawnmowerman
Mar 8, 2012 02:51 PM
jbg
Nov 11, 2008 12:17 PM
