1974 XLH 1000 stooped running
Unhappy 1974 XLH 1OOO dead, please helpI’ve recently been given an XLH 1000 that sat for many years. Slowly rebuilding, new tires, brakes, fuel tank, re wired ignition & main harness, new battery, points, condenser, set timing and it was rumbling great. It was sitting idling and then….completely shut off. Now, nothing. No turning over, no lighting, just dead. It’s been a sad day for me. Checked wiring, everything seems tight. Could it be the ignition or lighting circuit breaker or the starter relay? Any thoughts would be greatly appreciated. Thank you in advance
This is probably not your issue but it is worth mentioning... It is not good for these engines to let them sit idling for any extended time. In particular we do not warm them up that way in cold weather - rather, we ride off with the idle speed set a bit high so it will nor stall, and reduce the idle speed a bit at each traffic light or whatever as we go along. They are not getting enough oil to the top end at idle.
Thanks for help
Thanks Iron Mick - Good to know about idle. Was running about maybe 1 minute. Checked and the engine still rotates in gear by turning the wheel so it’s not locked up. Good news there.
I’ll definitely check the voltage etc. soon. My garage is cold and I’ve been a bit sick. Hopefully will get out there tonight. Keep you posted with progress.
IronMick (12-08-2021)
Could be anything. Arm yourself with a wiring diagram and a multi-meter. Here's a link to a wiring diagram.
http://sportsterpedia.com/doku.php/techtalk:ih:elec08?s=wiring#sportster_xl
A burnt up fuse wire (if you have the fuse wire installed) would do it BUT I doubt it is that simple. One (of several) achilles heel on a '74 XLH is the RED wire running from Solenoid to Voltage Regulator...... any fault on this wire (including the fuse wire section if it's there) would disable everything. Here's a link to TSB 659 which outlines the fuse wire.
http://sportsterpedia.com/lib/exe/fe...in:tsb0659.pdf
Anyway, study the wiring diagram and work the problem with your multi-meter. They need to become your best friends, if they're not already.
Drice123 (12-08-2021)
Looking at the wiring diagram the '74 had no main circuit breaker.
For starters, I'd check the battery first as Dan suggests, then check the ignition switch to see if power is getting to the "B" terminal, and out the "I" and "L" terminals when the ignition switch is turned on.
And verify the negative battery cable is well grounded, with a clean tight connection.
FWIW:
- the RED wire from Solenoid to Voltage Regulator AND
- the RED wire from Voltage Regulator to Ignition Switch "B" AND
- the WHITE and GREEN wires from the Ignition Switch to their respective Circuit Breakers
HD's quick + inexpensive fix was to install the fuse wire..... but of course, the retrofit did not make it to most bikes.
Like you said, get intimate with the wiring diagram & a multi-meter & you will (should ?) find the root cause.
sasquatch_38 (12-09-2021)
