no oil to rocker
Long story short, put new oil lines on bike. when I cranked it to check for leaks, I noticed the return line swelling. Shut it off and found the line pinched under starter. Fixed it. Cranked it and checked for leaks. Noticed top end sounded louder. Checked pushrods and they were as dry as when I put them in after changing pushrod tube gaskets. Appears I messed something up when then pressure built up. What do I need to look for, and how bad did I mess it up?
RE: no oil to rocker
Check to make sure lines are connected correctly, pump must be primed when oil lines are replaced, loosen \\;presure switch with motor running and allow about 3 ounces of oil to run out. \\;
I've done that. I can take line loose at cooler (return line to tank) and have oil flow. I can remove seat and take return line loose at tank and have oil flow. But doesnt seem to be getting oil to rocker. Can I remove that little allen screw on front/right side of rocker box and check for oil? Seems to be flowing back to tank, just not to top end. Didnt know if there was something in oil pump that seperated oil and sent to top end and botttom end. \\;
yes you can remove the allen nuts to check for oil flow
I can pull screw when I get home, but I'm about 99% sure that theres no oil getting to it. If so, what would have happened when the pressure built up that would be causing this.
I cannot believe that at all. Nothing could cause oil not to get to the rockers if the oil is getting to the crank it is getting to the rockers......pg
Your probably right again. I'll explain but will have to post a dozen times because I keep getting "error" message when I type more than two sentences.
When I changed hoses I just bumped her over for a second-long enough to get flow out the hose for a second or two. Today I was going to bump her for a awhile to let oil drain in pan instead of on floor.(took return loose at cooler and put pan under oil cooler) Got good flow, then a few drops, good flow, a few drops, etc. Appeared the pump wasnt pumping real good.
Pulled pump and turned it over and removed bottom. Blew into feed port and had trouble blowing air through it. Took a deep breath and blew hard and something small and light bounced off my stomach (I was sitting in chair at time with opening looking down) Suddenly the feed port is open and moving air freely. Not sure what came out, didnt see it and couldnt find it..but bet it was restricting flow most of time and blocking it some of time.
Piniongear, do you think this could be the culprit? Hope you can say yeah. And while the pump is out, what do I need to do to it besides new o-rings and gasket? Not sure I want to take it apart too much since I think it probably works when it can get oil. Not sure where the piece of debris came from, but just another reason to get an aftermarket oil cooler.
© 2024 MH Sub I, LLC dba Internet Brands
