rear shocks
Hello again,
I have a 75 sportster that is running great, the on ly problem is that I am a big guy and when I ride solo, the rear end bottoms out on some bumps and the rear tire rubs the top of the fender. I believe that the original shocks are still on this beast and was wondering everyone's opinion on a good replacement shock. If it were just me riding, i would just deal with it, but my lady wants on there too and even though she is a little thing, with the extra weight I know the bumps that haven't bottomed me out will botoom us out! So...any personal opinon on this subject would be great. You guys rock!!! |
i had the same problem i used a set off of a 2001 wide glide, just changed the bottom bushings,they were the same length as my stock ones(my ride is a 84) i am not sure how long yours are.
Originally Posted by shepdog
(Post 5051526)
You can e-mail or phone Progressive, tell them about your bike and your weight, and they will make a recommendation. Have not done this myself but this is what others say.
(Post 5051526)
They work and they can be customized to fit but they are good solution. As Mick wrote buy new shocks, 14.25" is original length in -75, I have good experiences PS products. |
no problems at all, same length,ride is great, no bottoming out just didnt have the extra cash for prog. shocks these were new got the at 1/4 cost of new i am a big guy i think i make up any dif. in weight between the dyna and sporty!
I had the same problem on my '73 & I called Progressive & the shocks they sent rock!
thanx for all the input, i ordered the heavy duty progressives today, can't wait to put them on and ride smoother. thank you once again
(Post 5053302)
in your -84 lower mounting point is in above rear axle. In -75 lower mounting point is middle of the swing. So in newer frames rear shock is almost vertical and end of swing arm, in older frames shocks are about 30-40º angle in middle of the swing arm. In normal highway there isn't so much difference ( even if you riding with hardtail) but in twisty farmroad you can tell difference at once. So were and how you are riding makes difference. |
I put a set of FXDX sport shocks on the rear of my '83. The springs are a little stiff - I only get about 1/2" sag when I'm sitting on the bike with the springs on the lightest preload. I like a bike that's stiffly sprung, so no problem there. The problem with putting stiffer, better shocks on the rear is the front end then seemed to handle like junk. The new shocks were 3/4" longer than the stockers. That, and the stiffer springs made the front end feel mushy and the bike wallowed in fast turns. Solved that with a set of Progressive springs in the front with 3/4" preload spacers and some 15 weight fork oil. The bike does great now - rides smoother and handles better, and 2-up is no problem.
http://i28.photobucket.com/albums/c2...2/P1000477.jpg |
© 2024 MH Sub I, LLC dba Internet Brands
