Knuckle Head A place to talk about Knuckle Head motors.
Pro Clutch
Old 03-23-2017, 10:58 PM
muddmann's Avatar
muddmann
muddmann is offline
Default Pro Clutch
Thinking about installing a Rivera Pro Clutch on my Knuckle. Anyone have any experience good or bad with one?
Old 03-24-2017, 05:59 AM
Tom84FXST's Avatar
Tom84FXST
Tom84FXST is online now
Received 18,204 Likes on 5,398 Posts
One of the best upgrades ever. Easy to adjust, reduced lever pull...have run one for 15 years...will never go back to a 10 spring clutch.
Old 03-24-2017, 07:17 AM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
Received 4,536 Likes on 2,872 Posts
as what tom said is exactly true - BUT the inner and outer primarys dont align like a later shovel, and IF i said IF the thickness of the clutch unit you are installing, is not the same across as a hat like the original clutch - you wont be able to install the outer primary
i even tried the york diaphram set up and it was too thick
ended up with springs but modded the tedds 2 piece alloy unit 3 nut to a 5 nut and used a 5 post hub, and it keeps it flat and straight for your foot operated clutch
i have a few knuckels in the shop could picture up one with out and one with if you really need to see but you have one -
having said that the green police clutch pack with a ram jet fixes almost everything in a foot clutch
have also used the koleen coated alto one sided clutch pack with great results
whats the issue you never said
Old 04-04-2017, 12:33 AM
muddmann's Avatar
muddmann
muddmann is offline
Thanks for the input. No issue at all just that a friend has one on his 46 and was saying how much he loves it. So I am thinking about trying one. I have heard that the York set up is the same but less money. I want to run a closed primary, and am changing over to a belt drive.
BuckeyeUltra
08-16-2023 10:21 AM
sexymanx4u
Shovelhead
07-22-2018 07:40 PM
blackchipjim
07-03-2012 01:57 PM
ULTHD
05-20-2006 09:05 PM
shineybike
11-13-2005 07:32 PM
Quick Reply: Pro Clutch
