Pan Knuckle
1 knucklehead engines feed main oil pressure oil out of the cam cover to the rocker boxes via a split line to the rocker boxes - that oil has NO drain holes in the head or the jugs as well as the engine block ( say it again NO oil drains at all -- so how the oil is returned is vacuum - the oil is sprayed from the rocker shafts into the valve spring pockets on all 4 valves - that oil is picked up by metal lines at the bottom of the spring pocket holders - then those lines go into the top rocker boxes ( its all up hill last time i looked oil does not drain UP hill ) - they in turn spill that oil under suction into the pushrod tubes and that same oil is drained into the lifter blocks - and they are connected to a special port in the front of the breather valve < this is the spot the suction comes from - it then gets sprayed into the cam cover and returns to the oil pump - dont understand - look up knuckle oiling system diagrams read as you look
now if i say if the pan heads are 1963 to 1965 they will be external oiling heads - but need drains for the oil you feed to the heads has a way of getting back to the oil pump - earlier pan heads are internal oiling they had drilled passages to the heads and drains coming back to the flywheels all pans and shovels use drains in the jugs - heads and block - - shovels work a little different but it needs a feed and a drain as well and knuckle blocks are as described above have NO drains drilled
if it actually works would be interested in seeing what they did -- but like all engine mods done by questionable people i would have to see it work and what they did > my guess it does not work as expected
For the record he is not a questionable builder. He has been in business for 30 years, has built 100s of bikes, had cover bikes, won national and international shows and has a great reputation. He loves the old school stuff as he sees it as a dying knowledge set. If anyone wants to speak to him about this specific modification, or any other old school stuff, let me know and I will pass on his info. He is located in Framingham Massachusetts and the shop is American Motorcycle Service.
Thanks for the replies
I was at the Leesburg Bikefest yesterday and at the Full Throttle Ike Show there was a hodgepodge pan head that really caught my attention..
It looked like a 50s hardtail frame THE CASES WERE 47 it was a panhead. The sign just said 1947 panhead. Sadly nobody around understood why that didnt jive. I scratched my head a bunch looking at it. It was a running bike.
Im hoping its there again today. I want a better look at it. The jugs were pan too. I had never heard of anyone putting a pan top on Knuckle cases I want to see the oil pump and any lines. It was cool and sad. There are probably knuckle heads somewhere that need cases there is probably some original pan cases that need heads.
