M8 problems
#1121
14GuineaPig (12-02-2017)
#1122
#1123
#1124
#1125
What you are saying is not true.. Metal particles wont expand to block a passage.
What is more than likely true is that the oil cooled motors simply do not have any pressure at idle... There isn't any way to maintain pressure in the current oil cooled head system.. At idle all the oil flows through the head passages and pressure drops.. As far as I can tell the head flow is simply an orifice. As oil heats up, viscosity drops and more oil flows through the cooling lines to the heads. Pressure drops to 0.. They need a pressure / valve ball like on the oil jets..
Making an orifice smaller for the head cooling passage might help.
#1126
#1127
I've brought this up before with no response to it, probably due to my lack of mechanical understanding and description of it. And maybe also due to my inability to express my self in a way that would grant me the attention my question deserves. But a reply from someone who's savvy in the way combustion engines work would help me in understanding how HD tunes their motors per say, as well as adding some feed back on my theory as to why THIS motor's oil pump is unable to continue its delivery of oil above its body during the idle cycle.
What I do know is that most oil pumps are mechanically driven. They rely on forces the motor generates. And once the motor is shut down, then the pump will come to rest along with it as well.
Now, my understanding on how HD manipulates the firing order to achieve spark at TDC is by keeping both piston very close at TDC. Part of that potato potato sound recipe we like so well, no? This describes why HD motors revs so slow.
So, could it be that during idle, with revs dropping to a low max cause the pump to stop performing?
We know that under power, it works fine, so why not increase the timing just enough to allow the pump to work during idle?
Or add an electric circuit for god's sake.
#1128
Professor123 (04-24-2019)
#1129
#1130
The oil line that was recalled has came loose for a second time on my bike. Last time a brand new, slightly larger clamp was put on but guess its no good either according to the whole underside of my bike. Was on a day ride and all was great til I got an oil smell, started checking out the engine and found oil all the way up passed the cam cover, dropped down and bam......the complete underside all the way back to the rear tire was either coated or dripping oil. Not cool!!!!!! Just wanted to share and tell you guys to keep an eye on that line, especially the guys who got the ol 30 second recall inspection and "looks good" answer. Had I not stopped I was on my way to busting my *** on a back road from an oil coated rear tire.
