M8 problems
#1561
https://www.hdforums.com/forum/road-...l-made-it.html
Well, I was pissed and had a talk with the owner, store manager and service manager.
To ensure my bike is repaired properly, they decided to replace the stator and rotor just in case they were bad, though they tested good. They also are replacing the voltage regulator again, and thoroughly inspected the wiring harness.
They contacted with Harley Davidson Motor Company corporate engineers and had a lengthy discussion about the issue my bike is having, it turns out that they have a large number of customers with the same problem and the voltage regulators are currently on back order, 2 months behind.
Harley Davidson of Fargo ND has put alot of effort into resolving this for me, and it is greatly appreciated, I hope that the regulator they found for me is one of the good ones.
They also gave me a loaner until I get mine back.
#1562
Cylinder head finish/Oil leak
Just brought my 2018 Road Glide special in for 1K service. While checking it in the tech pointed out that the cylinder head finish is chipped off around the spark plugs.
The tech thinks Harley should replace the heads. He's contacting Harley and I'm waiting for a call from him to find out what Harley's reply is.
I also have a lot of oil on my right saddle bag and on the back of the motor.
Has anyone else experienced either of theses issues.
Thanks
Thanks
#1565
Thanks
Thanks
#1566
I took the four plugs to the dealer shop next day and showed them to the service writer. He said it is very unlikely that any damage was done from this looseness of the plugs. I told him that I felt vindicated after a half century of checking the spark plugs on every new motorcycle I've bought. Concerned that the factory put in the wrong plug, a broken plug, didn't tighten it, or something like that. In a half century I never found a spark plug problem during my inspections, and was starting to doubt the necessity of checking them out. Then, I found this on my new Harley.
This, and the half dozen or so other assembly problems I've found on my 2018 RGU, lead me to believe that something is not up to snuff at the engine plant.
#1567
Update: The service writer just called me.
After further investigation, what he thought was chipped finish on the cylinder was actually some type of unidentified material that washed off.
I ask what his opinion was as to what it could be and he had no idea but assured me that it wasn't chipped. What I didn't mention in my original post is that the dealer that has the bike now is not where I purchased the bike so I have no reason to think their blowing smoke up my ***. As far as the oil leak they thought it might me from a rocker. They did the 1K service and took it for a test ride and left it running for a while. They say they can't find any sign of an oil leak. They suggest I take the bike and ride it and return if I see any oil leaks.
I have read on some face book sites that it's not uncommon to se the breather spitting oil when the oil level is at the line on the stick. Some recommend to run it just below the full line on the stick. if I see any leaks I'll follow up this post.
#1568
#1569
It's my third Road Glide.
Absolutely love it. Still have my 2001 Fat Boy for around town but there's nothing like a Road Glide.
I was on my way to bike week in Laconia NH on my 2011 Road Glide Ultra when I got a flat rear tire.
I was about 5 miles from the dealership in NH. I rode in with a flat tire and road out on a new special.
Already added the detachable tour pack and pad for her. Haven't had much time to ride it. Only 1K miles since June.
This thing called work keeps getting in the way. When I get some time off I'll put some real mile on it. The joys of being self employed.
