CoolFlow fan
YMMV
Lon
Originally Posted by bones932
I wonder whether it would help too, to bring more airflow to the rear cylinder which tends to runner hotter. I had issued with the sputter thought maybe going from 2003 with Cable to Hydraulic.....sure a thin band there. Only problem I had was twice a check engine code which was 02 sensor rear running rich.
I had the cool flow fan installed by the dealer and they only charged me 1 hr. It's a 2.5 hrs job so I was treated very well.
The fan is worth it.
I'm going to make the argument that the fans cools both the passanger and the rear cylinder.
Consider the orientation of the fan,it is facing towards the rear cylinder. Remember we are talking slow speed.
This fan is drawing air in. Where is this air coming from?
Because of the fans close proximity to the rear cylinder, air has no choice but the be drawn across the fins of the rear cylinder, into the fan and under the rear fender well.
I've had mine for the last 1000 miles or so on my 2017 Freewheeler. Over that time we've been having a string of 100F+ temps. So far I'm lovin' it for the noticeably less heat felt coming up from the engine. I'm also using "Parade Mode" when the temps top 90F.
Ace Cafe Rat
Ace Cafe Rat
mjwebb (06-24-2017)
14GuineaPig (07-17-2017)
In my mind, I think of the fan as more of a heat containment device - it is pulling hot air, but not very rapidly, and this keeps the air contained within the general area of the cylinder and not rising up/out onto a leg/crotch. Hot air rises due to differences in density, so the fan is trying to overcome that innate tendency, which will slow airflow at the inlet.
Source: 5 different textbooks from my studies in mechanical engineering covering Fluid Dynamics, Thermodynamics, and Heat Transfer.
In theory it makes sense, but you are pulling HOT air across a HOT cooling fin. The airflow (circulation of air) only causes things to "feel" cooler, it does not actual translate to reducing heat (this is specifically in regards to hot air in a hot environment, obviously if you circulate cool air in a hot environment, it will in fact cool things). There is also a lot of open real estate on either side of the fan/cylinder to pull air from, and while the majority of air come from the cylinder, there is much more volume available from the open sides. Hot air is also moves more difficult to move because of the difference in density, and density's effect on viscosity of fluids (yes, air is fluid).
