Cost of 1st service
I just did the 5K myself and materials were under $40 dollars. That was with Rotella T6 full syn and a H-D filter.
The filter is now mounted just a bit higher and it was easier to get the tool on and rotate.
The oil pan takes 4.25 to come to the full mark. In the service manual it states 4.5 capacity but of course some is still in the cooler and lines. I put four quarts in and it showed two marks below full. Went for a ride and it was at the bottom of the marks which takes a pint to fill. On the 17's dip stick the marks are half the length of previous years. So when at the bottom it is not a quart like the TC's.
The primary was the same 38 ounces.
