Anyone doing the breather bypass on your M8?
#103
that's a great question, something I'm curios about..is it possible to get 'backed up', and is there any downside? not clear on if 100% stopping any breathing is detrimental in any way...and it's just a catch can like referred to..does it typically require cleaning, etc.
#104
It's definitely going to require cleaning maybe every 1K or less. Not a big deal, just clean it with brake cleaner and you're good for another run!
#105
Did that on my 15 Limited no power gain little more stinky occasionally and it does requires cleaning very gooey stuff I had little filter hanging on the bottom and I would spray brake cleaner on it often.
mjwebb (07-30-2017)
#107
I just did something similar to what FurryOne has. Nothing detrimental. I see all positives as none of that is going into intake, valves, cylinders, and top of pistons. I would think maybe a little less than stock configuration of oil comes out as there is no low pressure to pull oil into intake. How often you clean/dump is a function of the amount your bike slobbers and the size of the catch can. I will check after a 1,000 miles and see how much is there. Then that will tell me required frequency for emptying.
#108
Robertashby (04-07-2021)
#109
#110
