Anyone doing the breather bypass on your M8? - Page 2 - Harley Davidson Forums
Go Back  Harley Davidson Forums > Harley Davidson Motorcycles > Milwaukee Eight (M8)
Reload this Page >
Notices
Old 11-28-2016, 07:25 AM
Nomadmax's Avatar
Nomadmax
Nomadmax is offline
Originally Posted by SWThomas View Post
Can someone educate me? How does the oil level in the pan dictate whether or not there will be oil coming out of the head breather bolts? I mean, the oil is pumped up to the heads and drains back down, so in theory no matter how much oil is in the pan the same amount is going to be pumped to the heads, where the breather bolts are. I just don't see how running the oil level lower would reduce the breather issue.
Now you've done it Marine!
Put your steel pot on and hunker down
Old 11-28-2016, 08:38 AM
cruisinmann's Avatar
cruisinmann
cruisinmann is offline
Senior Rider
I don't have the answer but owning and flying aircraft for 30 yrs if its filled to the top level mark it will blow out 2 qts in 6-8 hrs everytime leave it at 2qt low mark stays there for next 30 hrs .Now it holds 12 qts of oil. Also air cooled engine. Not saying it relates but I know for fact with those engines it made a difference
Old 11-28-2016, 10:46 AM
Max Headflow's Avatar
Max Headflow
Max Headflow is offline
I'm not sure if the M8 has the affliction but it was common for Twin Cams to blow a little out the breather if running the oil level near full. I suspect that it stems from the savenge system and the pressure pulses in the case from both pistons roughly going up and down at the same time. The scavenge pump has a flow rate that greater than the feed pump so oil scavenged from the motor is aerated when returning to the oil tank. Lowering the oil probably helps to keep the system in balance.. Once out of balance the air in the crankcase likely sees a heavy oil mist that is hard to separate at the breathers. Running the motor at higher Rs for long periods of time makes them bleed more but lowering the oil level in the tanks definitely helps. It wouldn't surprise me that the M8s have the same issue as the scavenge system is close to TCs.
One of the features of the M8s was supposed to be a less misting at the breather due to a better separator but HDs have been blowing a little out of the breathers ever since they started making big twins..
Old 11-28-2016, 02:30 PM
CR3999's Avatar
CR3999
CR3999 is offline
I run the breath bypass on mine the day I brought home. Pretty simple and cheap mod.
Old 11-28-2016, 03:13 PM
mjwebb's Avatar
mjwebb
mjwebb is offline
they still do, despite some of the claims it's a thing of the past..already changed air filters on both our M8's at 3K miles..same rules apply as always...midway on the dipstick HOT is prudent
The Following User Says Thank You to mjwebb For This Useful Post:
16Slim (11-02-2018)
Old 11-28-2016, 03:50 PM
fourburgs
fourburgs is offline
Senior Rider
Originally Posted by cr3999 View Post
i run the breath bypass on mine the day i brought home. Pretty simple and cheap mod.
how ??
Old 11-28-2016, 06:28 PM
George Bryce
George Bryce is offline
One Of The Regulars
And add to this good explanation, at some rpm/load, range, the top piston ring will lose seal with the piston and more blow by, than the designers hoped would blow, will leak some pressure into the crankcase and blow oil out, into the breather system.
The Following 2 Users Say Thank You to George Bryce For This Useful Post:
16Slim (12-02-2018), lp (11-28-2016)
Old 11-28-2016, 07:56 PM
CR3999's Avatar
CR3999
CR3999 is offline
Originally Posted by fourburgs View Post
how ??
I have some pictures to upload, but the little picture button is not working for me. What's up with that?
Old 11-28-2016, 08:00 PM
rjjj629's Avatar
rjjj629
rjjj629 is offline
bwoltz might be right that it's because of the scavenge system plumbing
I'm betting that pressure plays a role too. The more oil you have in the pan means the less air space you have on the supply side of the pump. As oil temp increases the pressure inside the chamber will increase faster with the restricted space. All the pumps I've worked with react to an increase in supply side pressure with a corresponding increase in output pressure.
In any case it's got me curious. I'm probably going to spend a little time with a pressure gage on the breather output and see how it changes with oil fill level.... once riding season is actually over that is.
Old 11-28-2016, 09:32 PM
CR3999's Avatar
CR3999
CR3999 is offline
Pull the stock hoses off and throw away.
Drill a hole in the location of your choice in the air box.
route to ground or install a catch can. Looking at the SE AC there will be some drilling the backing plate as they they reuse the same bolts as the stock air box. Also the air box is a lot closer the jug. There's not enough room do install like the twin cams, as there isn't enough room.
This is the way I did the by pass. Your plan my vary.
The Following 2 Users Say Thank You to CR3999 For This Useful Post:
FLshovelhead (06-30-2018), Riverside Joe (02-11-2018)
Quick Reply: Anyone doing the breather bypass on your M8?
Featured Sponsors
Vendor Directory
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
