TTS100-M8 cam test
TTS100-M8 cam test
Here is the new TTS100-M8 cam results. The chart is a Stock 2017 107 Road King with 4.5” Street Cannon mufflers #64900552 and a SE high Flow Air Cleaner #29400246. STOCK head pipe with cat!
Then with the SE8-447 cam
Then with TTS100-M8 cam
This cam is going on for EPA testing but currently it is not EPA or ARB approved. Keep in mind that this test was done with the stock headpipe (with cat)
Yes he did. Right now the testing is being done using the bolt on parts being offered by HD, we think this is what the majority of the people that are concerned about warranty will be wanting. Which is the reason for testing with the stock headpipe. We're not planning on getting into the who can make the biggest numbers race at this time. As testing goes and base MAP development gets now underway we'll see some more unrestricted exhaust options
We designed these to meet current emissions standards and are happy with the results. Now the process of going through the emission certification is next, this is typically a three -four month process but can and has been much longer in the past. Working with the ARB and then the EPA is no pleasure at all. They have two speeds they work in, sloooooooow and stop.
The following 8 users liked this post by Steve Cole:
09 YELLOWBIRD (12-27-2016),
BrokenAnchor (02-05-2017),
cmashark (12-26-2016),
DTTJGlide (12-26-2016),
Eccool (12-26-2016),
and 3 others liked this post.
