Non OEM Harley heated grip install
For ROCKOUT information & purchasing please click the LINKS below...
__________________
NO, they DON'T all do that!
Also on amazon.com...
Ashnic (12-29-2016)
That was my plan. Thank you for the pictures. Strange that the manual shows the location for the Interconnect in the fairing, but looks like this schematic shows it under the gauges. I will likely have it up on the lift tomorrow.
Great..would really appreciate any light you can shed on this..seems like there is a few of us with this issue..
Ok, so first the disclaimer...
If you burn down your bike, your house, your neighbor's house.... it's on you. You followed the advice of some guy on the internet lol
So, it seems to me that if the P&A accessory plug in the fairing is switched (I think it is), then you don't need to run your third wire anywhere else. You can just twist it together with the hot wire & use that & ground. You would only need to run the third wire to a switched source if you used the P&A accessory lead that goes straight to the battery for your +/- 12v.
This is basically how the stock heated grips with a batwing fairing work.... just 2 wires (and the left/right interconnect joint)
