Just Rented M8 Road Glide 340 mile review.
I got a new loaner SG while my RK was being serviced. Put a little over 400 miles on it in a day and 1/2.. It had 1900 miles on it when I got it.. The clutch worked much better than the clutch in on my 17 RK. When I got the RK back the operated the same as the SG as far as the friction zone goes. Before it would grab and jump if you changed the throttle while in the friction zone. They used Syn 3 in all holes.. I suspect that oil type might have helped.. Clutches on both bikes still clunk on lower gears.. The nice thing is that there is no compensator rattle like on the 6 speed TCs.. I wonder if the new comp will fit the TCs..
Handling and suspension are great.. It can get a little flexy if you push it hard enough.. As stated the front is a little stiff. For me the rears have damping quality same or slightly better than Works but not as plush in sharp bumps as Ohlins. I wonder how the fronts will do with lighter Oil and possibly springs.. I like the stock tires.. Yeah I know HD fixed the tires in 09..
For guy that like to keep the RPMs low the power is real good on the stock M8.
The Specials work so much better with std length 13" shocks (air or coil-over) it's not even comparable...especially when riding a passenger and/or loaded for travel.
Bob
Clutch feedback
Mine is smooth as butter on the upshift, but it too has a just a click on the downshift. No feedback in the clutch.
I don't care for amount of effort needed to hold the clutch full in. My solution was to just pull it enough to disengage and hold it their. Then it's not so bad.
I think the handling is great. I find low speed maneuvering even easier than the Super Glide I traded in.
