What Size Wheels For My 2017 New Road King
Apparently the 17" option was discontinued after 2013 models. They are shown in the parts fiche from 2009 to 2013.
These are the specs from a 2010 RKC
Front Tire
130/90B-16 Rear Tire180/65B-16
Only difference is your front now is a 17" and this would change the front to a 16", I don't see any reason it wouldn't be just fine. Someone will be along soon to add to this. These will require tubes also. But will give you that Classic Look
Front Tire
If you're thinking of those 16" on ebay for approx $900, beware those tires may be getting "older" relatively, if they haven't been replaced. You need the Date Code and you may need to to replace them soon, regardless of mileage.
I may have a set of 09-later 16" wheels, I don't recall if they're Aluminum "Profile" or Std Steel "Drop center", but I can check on those
http://www.ebay.com/itm/Harley-David...3D122250837493
http://www.ebay.com/itm/Harley-David...3D152395549298
Two sets of profile wheels and tires.
Make sure you get the touring wheels with rubber cush drive rear, not softail ones with a solid mount pulley.
