Reduced Reach Clutch Lever
Old 05-01-2017, 09:13 AM
Yzzyx's Avatar
Yzzyx
Yzzyx is offline
After using the new lever for a couple hundred miles, I think I am not a fan of it.
My hands are big enough for the regular lever, though.
If anyone wants my lever for $100 (Plus $5 shipping) just PM me.
It is like brand new, of course.
  #102
Old 05-06-2017, 12:28 PM
funbikerchick's Avatar
funbikerchick
funbikerchick is offline
I just bought both the brake and clutch levers for my '14 Heritage. Will I need to purchase anything else to do the install such as clips or O-rings, etc.
  #103
Old 05-06-2017, 12:32 PM
smitty901's Avatar
smitty901
smitty901 is offline
Received 9,603 Likes on 5,172 Posts
In most cases you reuse any extra parts that are needed. 2016 and older are different than the 2017.
You have a couple extra step so it.
funbikerchick (05-06-2017)
  #104
Old 05-06-2017, 12:33 PM
PootieTang's Avatar
PootieTang
PootieTang is offline
For a 2014 Heritage, I have no idea. On my 2017 SGS, no. Just reused the same C-Clips
  #105
Old 05-06-2017, 01:51 PM
Firenailer's Avatar
Firenailer
Firenailer is offline
PT - did you slide out and re use the plastic bushing and depression cap for the hydraulic plunger from the original lever or just slide in the Oberon?
  #106
Old 05-06-2017, 06:33 PM
PootieTang's Avatar
PootieTang
Video I watched before installing my levers. Clutch starts at 7:00 in. Very simple. I didn't bother with putting in extra grease.
  #107
Old 05-21-2017, 11:44 PM
Eric Hytinen's Avatar
Eric Hytinen
Eric Hytinen is offline
6th Gear
Default Rear brake pedal
smitty were did you get a different rear brake pedal? I just ordered some adjustable break and clutch levers from psr-USA.com.
  #108
Old 05-22-2017, 04:43 PM
BigDogIdaho's Avatar
BigDogIdaho
BigDogIdaho is offline
Originally Posted by Yzzyx
Thanks for the help!
I feel dumb. I didn't see the number on the dial.
I can use #2 with my foam grips. #1 will stall the bike when stopping.
My lever has settings from #1 to #7.
Does anyone have a picture of the brake lever installed?
Thanks!
I noticed that on the one I got for my wife as well. At setting 1 it wouldn't start unless in neutral. 2 was fine.
  #109
Old 06-24-2017, 12:03 PM
wildeano's Avatar
wildeano
wildeano is offline
I just installed my oberon adjustable clutch lever,,, what a huge difference.. My question is, did anyone remove the bushings from their stock lever, or just slide the new one in. Thanks,,,,,,,,,,,,
  #110
Old 06-24-2017, 12:11 PM
wildeano's Avatar
wildeano
wildeano is offline
As far as i can tell by trying, the original parts dont come out. But, i have been wrong before....
Quick Reply: Reduced Reach Clutch Lever
