I just bought both the brake and clutch levers for my '14 Heritage. Will I need to purchase anything else to do the install such as clips or O-rings, etc.
In most cases you reuse any extra parts that are needed. 2016 and older are different than the 2017.
You have a couple extra step so it.
For a 2014 Heritage, I have no idea. On my 2017 SGS, no. Just reused the same C-Clips
PT - did you slide out and re use the plastic bushing and depression cap for the hydraulic plunger from the original lever or just slide in the Oberon?
Video I watched before installing my levers. Clutch starts at 7:00 in. Very simple. I didn't bother with putting in extra grease.
I just installed my oberon adjustable clutch lever,,, what a huge difference.. My question is, did anyone remove the bushings from their stock lever, or just slide the new one in. Thanks,,,,,,,,,,,,
