The All things ROAD KING SPECIAL THREAD
#1261
I've seen several early-mid 2000's RK stock windshields posted for extremely cheap in my area on craigslist. Those should work on my 18 RKS as long as I picked up the $30 kit from HD that provides the bolts, grommets and acorn nuts right? thinking about riding with one for a couple of months then powdercoating the brackets and putting a freedom shield onto them.
#1262
Oil, Gas & Leather (04-20-2020)
#1263
#1265
#1267
I have a '18 FLHRXS, and I want to install the Bullet Front Turn Kit, part no. 67800167. Catalog at Harley says it doesnt fit my model, is this bullshit or is the hole spacing different on the earlier models?? They make a chrome kit for this currently, but I dont like the wide bracket or the fact that I have to take it to the powder coaters for work....any help appreciated.
Also, good method to remove reflectors on the forks without messing up the black finish??
One more thing, lmao, I want to change to Wild1 504 handlebars, Harley 69577-6A are similar but chrome, is there a black version somewhere....I want it to fit perfectly on the stock risers without adapters or other crap...
THANKS ALL!!!
THANKS ALL!!!
#1268
THANKS ALL!!!
THANKS ALL!!!
#1269
#1270
that black kit is for a SG fairing so it fits weird. Once you remove the reflector use your finger to roll the adhesive piece and it will remove it pretty clean. Some goo gone on a micro fiber towel helps clean the rest. It does not take much to heat them up so use a lower heat setting.
