Milwaukee 8 fluid question
Not looking to start a brand debate here. I just have a question.
about to do my 1000 mile fluid change.
obviously I'll use synthetic 20w-50 for the engine.
Either amsoil or redline tranny fluid, or Mobil 1 75w-90 gear oil.
what I don't completely understand is the requirements for the primary.
could someone explain what I should be putting in the primary?
thanks
thanks
The primary contains the clutch - don't just put any oil there is my opinion.
Ideally, use a motorcycle oil that is JASO MA/MA2 certified. JASO is a Japanese standard that is very strict concerning motorcycle clutches.
If you trust Harley, use their primary fluid. Amsoil also makes a JASO primary fluid at the same cost as Harley.
Personally, I'm a "change often" guy, so I use Mobile1 Racing 4T 10w40 which is JASO MA/MA2 certified. I'ts $10/quart at walmart, but Mobile1 routinely does rebates which will lower the price down to ~$7.50/quart which is half the price of Harley and Amsoil...at the half the price, you can change 2x as often and your primary will love you for that
I'm with GTK I recommend HD Formula plus as a precautionary measure. By 5k or maybe sooner you will know if you have any migration issues. Not all trans fluid compatible with wet clutch. I like to use dino for first 5k in motor also. Just my opinion gives it better chance for things to seat up
Yeah, but for anybody else out there that has this same question, I'll have to agree that using Formula+ until you're sure you don't have a transfer problem is the best policy.
