who's been having to add transmission fluid?
Old 05-12-2017, 10:14 PM
mjwebb's Avatar
mjwebb
mjwebb is online now
Received 8,542 Likes on 4,431 Posts
Kinda makes you wonder if the issue some are having with low oil is simply due to seeing the oil on the stick..
sometimes for me, depending on the light, glare, etc. it can be deceiving, in those visibility challenges getting the dipstick horizontal immediately upon extracting it and rolling it on a paper towel is very obvious and accurate..I'd never add fluid if I wasn't 100% sure of the level
Max Headflow (05-12-2017)
Old 05-12-2017, 10:25 PM
Max Headflow's Avatar
Max Headflow
Max Headflow is offline
Received 5,252 Likes on 3,626 Posts
I use the paper towel if I have trouble seeing the erl..
mjwebb (05-12-2017)
Old 05-12-2017, 10:28 PM
TwiZted Biker's Avatar
TwiZted Biker
TwiZted Biker is offline
Received 47,919 Likes on 17,474 Posts
Yep I do a black wire tie dip to check mine, factory dipstick is useless as condoms in a convent. Can't see the oil it's so thin.
mjwebb (05-12-2017)
Old 05-12-2017, 10:31 PM
Northside's Avatar
Northside
Northside is offline
Originally Posted by Retrop
I am curious as to why you switched to a 140 wt. gear lube in the transmission. That is pretty heavy.
I think you'll find that 85w140 gear oil isn't much heavier than 20w50 engine oil that a lot of guys run in their tranny. Gear oil and engine oil viscosities are measured differently. Does it make sense to run gear lube in a transmission rather than engine oil? Does to me and Bel Ray is great stuff!
Old 05-12-2017, 10:37 PM
mjwebb's Avatar
mjwebb
Yep dipstick is useless as condoms in a convent.
I was going to say as worthless as **** on a cow but I like that one!
Crowbar1 (04-13-2018)
Old 05-13-2017, 09:28 AM
SWThomas's Avatar
SWThomas
SWThomas is offline
Spectro 75W-140 is red so I can see it easier. I honestly don't see there being an issue if the trans it a few ounces too low or too high. Not gonna hurt a thing or degrade performance at all.
TwiZted Biker (05-13-2017)
Old 05-13-2017, 09:04 PM
thereal142's Avatar
thereal142
thereal142 is offline
I have used BelRay in my transmissions for years. I trust it completely. For reasons I can't explain I prefer it over Redline Heavy Shockproof, probably due to the Redline's weird appearance. I run mine at or slightly above the full line when hot. A couple ounces over won't hurt anything. I don't ride with the dipstick in the bike; I have another dipstick that I cut the stick off from and I run that on the bike and leave the dipstick in my toolbox. Probably a freak deal, but there have been a few cases of the stick metal fatiguing and dropping into the tranny and locking up the box. No thanks.
Old 06-01-2017, 09:25 AM
Fat Bey's Avatar
Fat Bey
Fat Bey is offline
Same thing has been happening to me !
I'm still in the process of trying to find out where it's going.
It's definitely NOT leaking out !
I've looked at every possible explanation I can think of along with my main dealer mechanic , but it's still a puzzle !
Old 06-01-2017, 09:53 AM
Red's Avatar
Red
Red is offline
Check out the "gear oil level" thread in the M8 section
Old 06-01-2017, 04:03 PM
Retrop's Avatar
Retrop
Retrop is offline
Black wire tie dip??? What is that?
Quick Reply: who's been having to add transmission fluid?
