who's been having to add transmission fluid?
Old 01-20-2019, 09:17 PM
CR3999's Avatar
CR3999
CR3999 is offline
Originally Posted by Dynabob64
That is your tranny's entire capacity. You were running the tranny dry and that is a real problem.
It was not at one time. It was over the course of the trip. I did install the larger push rod last week. I'll report once I get some miles on it.
  #3052
Old 03-19-2019, 07:41 PM
bob prosser's Avatar
bob prosser
bob prosser is offline
Stage IV
Default m8 oil transfer
My 2017 M-8, along with my co-plaintiff, are in the shop for the last, best and final fix to fix all fixes. We pick them up tomorrow and drive 1000 miles and re-measure the fluids. If there is 5 0z's or more fluid transfer HD will buy back our HD M-8's. Court documents.
The HD shop put a vent in the primary very similar to the one in the transmission. Will let you know in 1000 miles.
VDeuce (03-19-2019)
  #3053
Old 03-19-2019, 07:53 PM
VDeuce's Avatar
VDeuce
VDeuce is offline
Interesting, please update us. The vent is reported to work sometimes, not always.
  #3054
Old 03-19-2019, 08:00 PM
F150HD's Avatar
F150HD
F150HD is offline
Received 1,270 Likes on 836 Posts
definitely following this. thanks for posting updates when you can.
  #3055
Old 03-19-2019, 08:05 PM
KrustyKush's Avatar
KrustyKush
KrustyKush is offline
Lordy. 5 oz in 1k miles?
  #3056
Old 03-19-2019, 09:05 PM
Long time rider's Avatar
Long time rider
Long time rider is offline
Just to be clear here, this is not a class action suit? Did you and your co-plaintiff have to file suit in a local court. I hope you get the results you are looking for.
This reminds me when Harley crank shafts were having a lot of run out problems a few years back. Suddenly the MOCO changed the allowable specs from 4 thousandths to 12 thousands. Beware folks, this company has a long history of doing crap like this to avoid taking care of their design errors.
  #3057
Old 03-20-2019, 07:17 AM
RK14SGS's Avatar
RK14SGS
RK14SGS is offline
if you have any mountains near you, make sure you hit them within the 1000 mile window. My transfer was nearly double in the mountains, versus regular daily interstate commute. While I don’t solid evidence as to why, my hunch is the crankcase pressure and ventilation changes are greater with the sudden deceleration and accelerating. My riding is more aggressive than just the normal steady cruise. Not sure if you have the same condition or any hilly areas to load the engine through a wider range, but just thought I’d share my experience. 4-6 ounces in 200-400 miles in the mountains easily. Doubled with the deflector button installed.
  #3058
Old 03-21-2019, 07:30 AM
Bobjv's Avatar
Bobjv
Bobjv is offline
Thats been my experience also, way worse when riding in mountains.
  #3059
Old 03-21-2019, 08:29 AM
Steve N,'s Avatar
Steve N,
Steve N, is offline
Good advice. I had put on about 23,500 Km (of varying riding conditions) with absolutely no transfer issue at all. Then one weekend I had the occasion to ride through some mountains. One in particular had an extremely long and steep grade in warm conditions. The transmission oil was off the dipstick prior to my next service. We measured the oils to find that it had transferred 8 ounces within the last 4000 km.
  #3060
Old 03-22-2019, 05:07 PM
yzernie's Avatar
yzernie
yzernie is offline
Just got a 19 RGU. Other than checking the gear oil level regularly is there anything else or other symptoms I need to keep an eye and ear out for?
Quick Reply: who's been having to add transmission fluid?
