who's been having to add transmission fluid?
#511
FWIW.. I checked my levels the other day. Trans was top of the F and primary primary a tad high being just above the bottom of the clutch plates.Went for a 200 mile ride today. When I parked it, I noticed some oil splash on cover for the rear cylinder exhaust and oil around the trans dipstick. Unscrewed it find the O ring tore when I installed it last time. My point is, if the oil is well below the surface the dipstick threads into, how does oil get up to it and pushed out through the torn o-ring and out the hole? The trans level was fine so it I didnt lose much, but I'm wondering if there isnt pressure in there, high enough to force oil up and out?
#513
#515
Today you need to repeat the test with two glasses. This time lay the straw over the top of both glasses not in them, suck and blow away. When you grow tired of sucking and blowing, as a reward you can then empty the two glasses without the straw. I recommend using Crown Royal Cask No 16 as a test fluid.
mjwebb (07-04-2017)
#516
My build date is 8/16. 17 Limited. First one to buy one at my dealer..Rubber City...when they came out. They did the 1,000 mi. couple weeks after that and rode till around November. Brought it back out and ride everday possible when weather broke in spring. Checked tranny today cold after reading this thread and dipstick is right at top of the X and oil is clean and prmary was just right .
#517
#519
I had a friend checking on the bearings for me and we found somethings I had seen but did not know. From looking at my '14 transmission and the new '17 the bearings looked different. As it turns out the '17 is suppose to use two different bearings by part number. I do not know which is which at this point, as my bike is together at this point and I'm going for a ride today. This could turn out to be as simple as putting the wrong bearing in the wrong place! That would explain why some are getting lots of transfer and others are not. I had him order the two bearings from HD and will see what we see when they get here. I can then compare which one is supposed to be on which shaft and see if mine is correctly installed.
The following 5 users liked this post by Steve Cole:
FM500 (07-04-2017),
Gamma742 (07-04-2017),
hattitude (07-04-2017),
mjwebb (07-04-2017),
MotoJockey (07-04-2017)
#520
