2017 Milwaukee 8 cams
Old 05-17-2017, 04:11 PM
Shahin7497's Avatar
Shahin7497
Shahin7497 is offline
Default 2017 Milwaukee 8 cams
I have a m8 fuel moto 2-1-2 exhaust and target tune with screaming eagle 447 tq cam. Would be worth to switching to woods cam or dragos?
Old 05-17-2017, 04:23 PM
Shahin7497's Avatar
Shahin7497
Default Tq447
Old 05-17-2017, 05:06 PM
Steve Helton's Avatar
Steve Helton
Steve Helton is offline
Originally Posted by Shahin7497
https://www.fuelmotousa.com/p-33193-dyno-charts.html Here are the dyno run's by fuel moto with woods cams some pretty good numbers.
Old 05-17-2017, 05:18 PM
Shahin7497's Avatar
Shahin7497
Default Fuel moto
yes I know, just hoping I can get 114tq without the 2-1 pipe. Either that or just do the 117 big bore. But I don't really need 135 tq
Old 05-17-2017, 06:14 PM
Steve Cole's Avatar
Steve Cole
Steve Cole is offline
HD EFI Guru
Received 3,430 Likes on 1,577 Posts
If your not in a hurry there are cams coming that will do just what you ask. Be careful when looking at dynosheets so that you compare apples to apples as your sheet is set to DIN corrections and it really should be in SAE corrections, as no one any longer uses the DIN corrections. What you are asking for is good torque ride off idle and that means the dyno sheet needs to show you the run starting down at 1500 RPM and on up the RPM band. Lots of sheets start above 2000 RPM and hide what you need to see down low, so that you focus on the gains above 5000 RPM. I do not know how you ride but my bet is you do not spend much time above 5000 RPM and mainly spend your time in the 2000 - 4000 RPM area. If so, look for the gains in those areas as that is what your going to be riding.
The following 4 users liked this post by Steve Cole:
BigDogIdaho (05-18-2017), ffltjeff (05-18-2017), ShitHouseRat (09-18-2017), Spy11 (06-16-2017)
Old 05-17-2017, 06:45 PM
CR3999's Avatar
CR3999
CR3999 is offline
I have the Woods 222 cam. I'm waiting and wanting something else.
Like Steve said, we need something that starts at idle and doesn't drop until around 42-4500 RPMs.
The next cam swap will be a piece of cake. I already replaced the cam bearing and have adjustable push rods.
Good luck in your search.
Old 05-18-2017, 05:45 AM
Steve Helton
Where does the 222 kick in i thought it was the torque cam.I have the 447 tq. harley cam it's ok but like you looking for more.https://tmanperformance.com/product/m8-200-ps/ Here is some more cams.
Old 05-18-2017, 07:15 AM
Drodrigueznyc's Avatar
Drodrigueznyc
Drodrigueznyc is offline
I think the 447s is a very good cam for low to mid range torque. I felt a noticeable difference when I went to the SE stage 2 torque cam kit w/V&H headers/mufflers and SE heavy breather. Not sure another cam will give you significantly more unless you go for stage III or IV. As mentioned earlier don't go by the dynos posted on manufacturer websites. They are sales tools and usually a bit exagerated. Search for real life users of those cams to see what numbers they are really getting. Also need to figure out in what range you want those increases. The 447s are designed for low-end torque. Below is a sample chart. Again take these things with a grain of salt.
Old 05-18-2017, 07:55 AM
BlkHillsBagger's Avatar
BlkHillsBagger
BlkHillsBagger is offline
I'm headed to Wisconsin to try the Wood 777 at the end of the month. It was recommended by both Bob Wood, and Jamie for the higher compression in the Stage III.
Old 05-18-2017, 08:59 AM
cruisinmann's Avatar
cruisinmann
cruisinmann is offline
Received 1,807 Likes on 627 Posts
Dyno all SE parts and tuner,stock headpipe . Dealer dyno tuned for what its worth not sure if going with fuelmoto headpipe will make much difference
Quick Reply: 2017 Milwaukee 8 cams
